April 6, 201115 yr Hey if you have trouble with that disty set up (shouldnt) but if you do Jerry can be a big help he is a really cool guy and knows his chit im donw there about every other weekend haha. Cheers R
April 6, 201114 yr Author Yeah i went and saw him...He gave me a disty and the escort coil for it Bill said he should have the flywheel done friday. Then I need it resurfaced and can start buttoning up whats left..
April 18, 201114 yr Author Been a slow process but getting closer All that is left is Wiring in the disty and alternator. Also have to Plug a few holes and find hoses for the radiator and the heater core.
April 19, 201114 yr nice......very nice this should be awesome. remember, the timing i dialed in on was about 18 degrees. so start there... cheers, b
April 22, 201114 yr Have a Question How did you guys mate the Radiator hose i brazed new outlet/inlet pieces onto a a stock ea81 radiator......it was not super fancy, but did not leak. cheers, b Edited April 22, 201114 yr by monstaru
April 22, 201114 yr just put a legacy radiator in it you will be much better off. And if you are in need of one i have a few and would be willing to sell one make me an offer. Cheers R.
April 22, 201114 yr Author Found some adaptors that worked at Ranch & Home (ellensburg Home depot) So the hoses are together. Now trying to find an ignition switch wire for my disty.. and the starter was giving me some trouble but got it working..
April 24, 201114 yr Runnin yet? When i get home tonight i want to hear that thing running Then we can make a quick run to the hills to test both our rigs this week after class
April 25, 201114 yr Author Ok....So i have power to the Disty and no power coming out. Hoping that the new module i ordered with be the solution
April 27, 201114 yr Ok....So i have power to the Disty and no power coming out. Hoping that the new module i ordered with be the solution that WAS a brand new module...........i'd look at the rotor and cap...unless you replaced that already of course.anyways.keep on truckin. chers, b
