Compression test results ???
EA82
Well, I did a compression test. Got 105 / 135, 80/ 140. Wet tested 80 and got 110. Pressure tested radiator w/ no coolant and air escaped from the 80 spark plug hole as fast as I could pump it in the radiator. 80 held pressure, a spoon of oil increased pressure but air from radiator rushes in...What going on?
Edited by Casino Loyale
if you have air passing from the radiator into a cylinder or vise-versa during a compression test, then you have one of two problems.
*bad headgasket
or
*hole in a cylinder exposing a water jacket
UGGGH only if they are falling out of the sky!!. give it to me if you throw it out. I have the last ea82 on earth, at least in my region.
sounds like blown head gasket. easy to fix. dont wasete a still good motor if you can fix it yourself. what if you get a junkyard engine and it blows a head gasket?
i have fixed these motors in WAY WAY WAY worse condition.
