April 1, 201115 yr my module is bad and i need to get one. does anyone know what years will interchange? it allows you to take the car out of park when you press the brake pedal. mine is a 90 legacy. here is a pic of the box http://www.surrealmirage.com/subaru/images/swap/shiftlockcontroller1.jpg thanks, mike
April 2, 201115 yr Pretty sure I have one from a 93 Legacy if that helps. I'll check on Monday unless someone has one quicker.
April 2, 201115 yr Author i'm going to try to get one at the junk yard tomorrow. thats why i needed to know what years are the same. but if i don't find one i'll let you know
April 2, 201115 yr Common problem. I just zip tie the shift lock linkage back so it never engages. Problem solved.
April 2, 201115 yr Author i never thought of that. if i don't find one at the right price today i'll just do that.
April 2, 201115 yr mine started acting up a few weeks ago and i put a rubber band on it. yhis week when the rubber band broke it was working again. so i left the shift ''surround'' off so the release button was accessable. next time it acts up i'll use a zip tie. never thought of that.
April 2, 201115 yr Author ok i put a zip tie on it and it's working fine. i might grab the module if i ever run across one but i'm not really worried about it.
