April 11, 201115 yr Something associated with the abs wont stop running. I pulled both fuses and it keeps running. Had to disconnect the electrical to it to make it stop. Passenger side front of engine where all the abs stuff is. What's going on here and what do I need to fix. TIA.
April 11, 201115 yr Author Fixed? I pulled the 2nd fuseable link in the black box on top of the abs unit and put it back in and the humming has stopped, abs light off, and abs functioning normally. TSB for sticking abs relays...can I get dealer to fix it for free? guess I would have to wait till it sticks again.
April 11, 201115 yr heh that happened to me once when I had my 95 drained the battery but it never happened again and I tried my hardest to make it stick again.. never got a replacement so I can't tell you if they will still do it free.. I'm sure they would if they dust off the old TSB book for this year.
