88 EA82T Posted April 18, 2011 Share Posted April 18, 2011 I think the fuel pump on my 88 GL10 died. It doesn't make any noise when I try to start it and it won't start. It used to hum for a couple of seconds when you turned the key on. I still need to troubleshoot a bit more but I wanted to get some opinions on my options for replacement. Looks like I have three options: Bosch N69417 for $256 at the dealer Carter pump for $140 Aerotec pump for $120 or so They all seem really expensive for a car that is 23 years old. Anyone have experience with the aerotec pumps? Just looking for some advice. Thanks. Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 18, 2011 Share Posted April 18, 2011 If I was going to spend that kind of money I would just buy a Walbro. Just about any in-line fuel pump will work, look for cheaper brands or a junk yard. Quote Link to comment Share on other sites More sharing options...
Quidam Posted April 18, 2011 Share Posted April 18, 2011 $78.10 for this one. Others listed there as well. Good luck! http://cgi.ebay.com/ebaymotors/NEW-FUEL-PUMP-ELECTRIC-SUBARU-LOYALE-CAR-PART-AUTO-_W0QQcmdZViewItemQQfitsZMakeQ3aSubaruQ7cModelQ3aGLQQhashZitem35b0cf16afQQitemZ230599628463QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Quote Link to comment Share on other sites More sharing options...
AWD TURBO! Posted April 19, 2011 Share Posted April 19, 2011 I would just buy a Walbro 255 o hold on i did $110 the e bay and the parts place pumps are junk! unless there oem i lost an mooter to a faulty pump Quote Link to comment Share on other sites More sharing options...
ruparts Posted April 19, 2011 Share Posted April 19, 2011 hi, the ground for the pump is in the ECM, i have had a couple of them do this same thing as you describe, and found the ground was the problem. you should check the pump first , not just assume it is bad. unplug it and connect it to 12V both pos and neg direct to see if it will run that way it might be a bad pump but check before you spend the money. Quote Link to comment Share on other sites More sharing options...
