Talking about how to improved MPG?
Holler NorthernWestern;
my suba is 87' wagon 5speed shift and EA82.
my best high is MPG 32 and over 450 miles by 14Gal. but i need to know what else parts for improved mpg??
So far; i was install for improved mpg.
*Oxygen Sensor, BOSH.
*Weber Carb 32/34.
*Fuel Filter, FRAM.
*Spark Plug, NGK G-power.
*Spark Plug wire, NKG.
*Band tires 34PSI for summer & 32PSI for Winter.
*5-30W oil. (only)
*No ARCO gas station.
*No leaky oil on the motor.
*Check no crack/leaky hose on the motor.
someone or everyone said that, try to install for new improved MPG-
Fuel Pump (if that would be work?),
Distributor (it's make a sense but alot of $),
and what else, humm??
come on, bring on for improved mpg on old Subaru!
:headbang:
you get good mileage. I have gotten 18 with the same cars.
Skinny tires aired up all the way, aerodynamic mods. that is all you have left to do with what you got.
Hi This is Jerry, i have an 85 EA81 hatch back and i drive 500 miles every week just to work and back. So with that i have installed a 93 imperza 1.8 engine everything all stock on the engine except air filter it has a cone filter. I use the stock Y pipe it all fit. I have a 86 RX 5 speed dual range tranny with 3.70 gears and a VLSD 3.70 rear also rear disc brakes. I am running stock tires 185/70R/13 now this is the kicker i am getting 38.4 mpg for now but i still have a bunch of things i want to do to get 40 mpg. The car weights about 1000 lbs. less than the imperza. Thanks Jerry
contary to what you installed *Weber Carb 32/34**
those Webers are not designed for fuel economy, they are a performance carb. The stock one is more efficient by quite a bit, even if the weber is tuned perfectly, a fresh stock carb will give better mpg.
You could bump the timing one more degree depending on how you drive it and if you use consistent same gas all the time.\
add another 1-2psi per tire. make sure brakes are well serviced, and nothing is sticking.
If you have a roof rack, take it off.
Carbed with an O2 sensor???
Cat nor plugged?
maybe a more economic muffler?
You never said anything about a new air filter? or a clean one?
no air filter
only have a carb with filter. -Weber carb 32/34. useful replace new carb filter every 6 monthly.
yea, i need new Catalytic Converter, it's could improved mpg?
Cat nor plugged?
only max to 35MPG ON ea82?
tell me what kind parts for improved mpg?
i can do replace some new parts as soon possible.
:cool:
fuel pump isn't going to help.
35 is really decent though for an EA82.
what kind of aerodynamics' fit on my subaru wagon 87'?
i'm inserting for it..
aerodynamics - remove your side view mirror, in most states you can legally remove one side - i forget which one it is.
here's another subaru owners quest for 40mpg, you might have fun with this:
http://www.subaruoutback.org/forums/61-general-discussions/13562-why-wait-diesel-my-quest-40-mpg.html
remove all excess weight - rear seats, carpeting, dash, heck....an XT6 will even drive without the instrument cluster in place - i've done that before it's really funny to drive around like that. :lol: you can remove bumpers and drill out the bumpers beams to remove weight, remove all excess bolt-age - there are always more bolts than needed.
get lightweight pulleys, under driven pulleys, remove your a/c, remove your power steering, convert to XT6 electric power steering.
cone filter intake or K&N filter.
lower the car - cut a coil spring off of each strut.
XT6's do a little better with a straight through muffler, the stock muffler sucks. that's a 6 cylinder with a craptastic stock muffler though, not sure about your carbed 4 banger.
switch to synthetic oils all the way around.
regrease all your wheel bearings with synthetic grease.
there's a million things you can do, the problem is the law of diminishing returns is going to set in. the more you do, the less return you get.
drive really slow. between 40-60 mph you'll see your best mileage.
FWD manual XT used to be able to get 40-42 mpg on all highway driving. given it's aerodynamic superiority (lighter weight?), and multipoint fuel injection spider manifold set up, and FI instead of Carb you're not likely to get that high without driving like grandma - 50 mph tops. 35 is probably about maxed out...you're hitting diminishing returns.
the thought that "every improvement gains you 1 mpg so 10 more improvements will net me another 10mpg" is way off base and not even close to reality. it's a curve and once you've done the major things and have a great running car everything else starts producing smaller results.
Well, if you want me to answer my suggestion, i will give you ideas i had for my 95 tercel
smooth hubcaps(oldsmobile 13's)
I have a bunch of plastic sheets that are meant for wire shelves, and i was going to make a 'cadillac' style cover for the rear wheels, and cover up the rear rollpan to make the bumper flush with the tire well and gas tank, and do the same for the front around various frame members.
I have already removed the back seal and passenger seat for the purposes of cargo storage and trunk pass through. Any fuel economy/aero/hypermile mods are an afterthought/side effect of removing the seats
on the www.subaruxt.com page, there are some interesting diagrams regarding the engineering of the xt body, based on the gl body and what they changed to get a .029 Cd, and this may give you some ideas
If you are so adiment about getting better fuel milage... have you thought about buying a GEO??? They get way better milage...
haha, i dont want to get GEO. i rather on wagon w 4wd. lmao.
AH! i forgot repair new fuel injection on EA82.
i should buy as soon.
haha, those outback wagon, im not inserting of it. but that's odd design like as future culture. :lol:
If you want to go all out, save weight. Pull the back seat. Pull the carpets, saving weight will save MPG. If you have steel wheels, put on alloys.
Your MPG is REALLY good already for an EA82
i almost forgot put new Fuel Injection. :)
my old fuel injection is very old, rusty and ruin out.
that's would be helpfully when get new fuel injection! im going plan buy on this June. :grin:
hopefully will get more than 34 MPG
i could help you if you know where is fuel injection from?
haha, where i can find svx transmisson?
it's hard to find it.
my suba tanny is 4.44 gear ratio...
How about this:
Install the 3.54 gear ratio of a SVX......:lol::grin::banana::eek::slobber::-\
a k&n air filter will work as good as no air filter...no air filter will drop your fuel mileage eventually to nothing, when the engine shells.:)
:banana: anything else idea how to get improved mpg?
Edited by Suba_GL_87
  • 1 month later...
you need new Vapor Canister!!! it would be help to boom mpg. i was buy cost $105 and it's worth it! :grin:
and pour to gas treatment too
  • 2 weeks later...
I did the ej22 swap in my 4" lifted '84 hatch w/5spd d/r 3.9 lsd. 235/75r15's m/t .
Fully loaded for a few days excursions 2750.. I get about 25-28mpg going up several passes backroads..
I have a ton of frontal area including the overhead rack and a large cargo box ontop.. The jeep guys hate me..:lol:
One off these days I'll loose 50lbs and lighten up the load ..
also when you need to fix something in bfe...it's nice to be prepared...
I just got some Bridgestone Ecopia tires... reviews on the internet said some people are getting slightly better mileage. And they are marketed as a high efficiency tire. Though... some of that may be attributed to gentler driving due to the new tires... I know I will be taking turns slower now so I dont wear out my nice new set... my old ones I could have cared less about.
