August 18, 201114 yr ive got an 87 gl hatch with the stock ea81 in it. two weeks ago me and my friend rolled it (only about 5 mph) the car looks to be fine but when i go to turn the key, nothing happens. not even the electronics work in the car. any ideas? ive spent a few days trying to figure it out and have NO clue... is there a safety feature that cuts the power when the car is rolled? Thanks for any help!
August 18, 201114 yr my guess here is when you rolled the battery hit the hood and grounded out that caused the main fuisable link to blow thus no power to the car. IIRC the Fusable link box is on the passenger side under the hood the links are just wire fuses and they plug in should be 3 or 4 of them. Cheers R.
August 18, 201114 yr ive got an 87 gl hatch with the stock ea81 in it. two weeks ago me and my friend rolled it (only about 5 mph) the car looks to be fine but when i go to turn the key, nothing happens. not even the electronics work in the car. any ideas? ive spent a few days trying to figure it out and have NO clue... is there a safety feature that cuts the power when the car is rolled? Thanks for any help! PICs..........:clap:
August 19, 201114 yr iirc there is a checkball in the fuel suppl line that if the car is rolled over, the check ball blocks fuel supply.. if you get nothing with key, then check all cable, grounds, fuses.
August 25, 201114 yr I dont know how to post pics directly on the board, but all you have to do is go to a picture hosting website. I use http://www.flickr.com/ Make an account kinda like you did on the USMB and then from there you can upload pictures of your choice. then you can copy the address of the picture and paste it in your post.
August 25, 201114 yr Create a photobucket. Upload your photos. Try to resize to 800X600 or 640X480. Copy the IMG code Paste that code into a Reply to Thread box like any other message.
September 28, 201114 yr Author got it all figured out! turns out there were a buncha wires that came undone.... kinda hard to see but here is a pic on its side and this is before the rollover, again kinda hard to see...
