August 23, 201114 yr I think I saw in a FSM or someplace that the postal versions had a express up and down for the driver window? I wonder if it's the switch that has that feature? I wonder if that would work to have express up on a non postal model?
August 23, 201114 yr I think I saw in a FSM or someplace that the postal versions had a express up and down for the driver window? I wonder if it's the switch that has that feature? I wonder if that would work to have express up on a non postal model? Yes, the switch is what has the feature (Not the motor) if thats what you were thinking. Every time I see a Postal Legacy in the junkyard, it has crank windows (Cause its a Brighton postal)
August 23, 201114 yr Author I'm thinking maybe I can go to the dealer and just get the switch? It can't be that much can it?
August 23, 201114 yr I'm thinking maybe I can go to the dealer and just get the switch? It can't be that much can it? Now since its the opposite side, will it still fit in the door molding? Aren't the swtich panels kinda oblong?
August 23, 201114 yr Author Now since its the opposite side, will it still fit in the door molding? Aren't the swtich panels kinda oblong? I think it should fit.. like the door locks the trim will fit left or right.
August 23, 201114 yr So, what are you going to use the express up feature for? Is it for when your at McDonalds, the drive-thru dude gives you the food, then you press "Express-up" and peal out so you don't have to pay for it?
August 23, 201114 yr Author LOL Not really it can be helpful in some ways.. but I can't figure why they would only offer it on the postal model.. the switch can't be that much over the normal switch.. and correct me if I'm wrong but I still don't think Subaru has any late models with express up. I know the dealer is not going to have them in stock i'm curious what they go for.
