bonvos winter warrior
im so glad i picked this thing up not only do i have brakes after bleeding them but i took some polishing compound ot the paint and its like brand new
  • Replies 235
  • Views 40.9k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • theres only one thing i enjoy more than a garage motor build...... thats one i get to watch not have to do lol
  • well i leaned something new about my engine the water pump is completly contained the cast pipe up top is what connects it to the cooling passages instead of having everything inside the block half ca
  • you would have to come to lapine and i have no way to pay ya lol but if your game pm me
Sounds great and I can see in your post that your enjoying it a lot. keep them posts and pics coming....:banana:
thanks biffanyus yeah i have a passion for cars i love working on them and this one is an awesome find i was just gonna make it a beater but after seeing how nice it is i want to keep it as clean as possible still gonna be my little rally wagon but im gonna take care of it not beat it into the ground
went to work on it today headed to my parents place and they werent there so i waited while i waited i busted out the polishing compound and got this as a result
on the left you can see what was polished and the right isnt done yet
almost brand new paint
then i started on the clutch
radiator out
disconnect some stuff
and its out
hard to tell from the pic but this disk is hammered
i have some cleaning in my future
and thats where work stopped due to having the wrong clutch disk
i found one on rock auto that im gonna get as well as a head gasket set figured i might as well do it while its apart
parts are in the way so hopfully next week it will have a new clutch and head gaskets (cheap insurance) and then all it would need is reg and its ready to go
alright guys there are so many hoses on this thing anyone have a picture or 2 of how everything is supposed to be routed? i want to make sure its all set up right so that i can properly tune this thing once i get the engine back in it as you know its a 78 ea71 non cat car
well i bought some degreaser at ace and went to town on the engine its clean now well cleaner parts should be here tuesday and my next day off is thursday so the clutch will be done as well as head gaskets then its time to drive it
gasket set came in only thing it was missing was an oilpan gasket O_o valve seals everything and for 20 bucks cheap insurance
use permatex ultra gray for the substitute of oil pan gasket. it is what the new ej's use.
i might just do that i wasent going to pull the pil pan off just gonna put some new head gaskets in it but after i do that damn near the entire engine will be resealed
clutch came in today i tore the valve covers off and checked to see if the cam was flat spotted and its not come thursday it will be on like donkey kong
edit ************ty cell pics lol
clean(er) engine
head gasket set
clutch kit
Edited by bonvo
alright i got off work today after working 8 days straight and dug into the subi
first i painted the valve covers
and air filter
used a silver base coat and anodized blue paint
then i got really busy for about an hour O_o
end of the night
tomorrow i finish painting the air filter stuff and put it all back together with new gaskets and a new clutch
Hey there, i like what you are doing with this car. I have two gen 1 wagons myself, one I drive every day. I really love these cars and you will too, I can see that.
thanks man yeah i love this little car i cant wait to drive it
ok started out today but cleaning the head mating surface
dad prying out the valve seals
passenger side pistons
drivers side yes she needs a good seafoaming
torquing down the heads
assembled
the stair-down
proof i did more then take pictures lol
empty
up.......
......and in
running
video of the quiet valves the timing and the dwell as well as the carb settings are way off its getting tuned tomorrow
threw the air filter on it to see how its gonna look
well i tried to tune it today and im thinking the carb needs a rebuild
carb rebuild kit on the way i was very tempted to pull the weber 32/36 off of my 610 just to drive it but decided against it considering i cant take my only running car apart untill this one is reliable so ill rebuild the carb and run it this winter then then next summer when the datsun has its twin side drafts on it the subi will get the weber i must say i love rockauto.com even with shipping the parts are still cheaper then the parts houses
tore the carb apart it was digusting i also drained the fuel tank because there was water and old fuel in it so with a rebuild and fresh fuel it should be good to go
rebuilt the carb and took it for a drive talk about a gutless wonder thing can barly get out of its own way but i love it lol
Nice!!!!:grin: I took my Brat out for a ride tonight as well.... I just love cruising around in it and having so many heads turn wondering "what the hell is that" or the older folks with the "I havent seen one of those in a long time" looks on their faces...:lol:
yeah still a few things that need to be done like i need to make the fuel pump work on its own rather then an alligator clamp on the positive side of the battery make it so the tires stop going flat (leaking from the bead) but other then that im basicly ready for winter in my little 4x4
My 1979 subaru wagon doesn't have the odd lug size I put ea81 white spoke stock rims on it the only problem I had was they're wider so I had to use wheel spacers. That and I converted mine to run off propane, I love my 79 goes any where in the snow
wouldnt that still be the odd lug pattern? the typical 3 lug pattern is 4x41/2 for most rwd cars and 4x4 on most front wheel drive
