bonvos winter warrior
bearings why you no here yet!!!
  • Replies 235
  • Views 40.6k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • theres only one thing i enjoy more than a garage motor build...... thats one i get to watch not have to do lol
  • well i leaned something new about my engine the water pump is completly contained the cast pipe up top is what connects it to the cooling passages instead of having everything inside the block half ca
  • you would have to come to lapine and i have no way to pay ya lol but if your game pm me
bearings are in tomorrow spoob starts happening
well today i got it put together and ready to drop the rebuilt motor in tomorrow tried something new and recorded the whole think its a little long
Edited by bonvo
got the subaru all back together it seems to run better and the motor is a lot tighter then before but according to the compression tester the results havnt changed beginning to suspect dads prehistoric compression tester but its still hard not to feel defeated after going threw all that and seeing those numbers
Dude, the video is awesome!!!....it's both educational and the soundtrack is a killer!!!. Try Emperor and Meshuggah when you record the test drive. :headbang: ...more :popcorn:
very glad someone watched the video i was worried because its so long people wouldnt watch it
nope no need thats what the gaskets are for no leaks so far
went out and messed with the oil pump a little as i was having low oil pressure at idle and put the last parts on it then took it out to seat the rings. im seriously doubting my dads compression tester at this point it runs way to good and way to smooth and pulls to good to still have 100 psi of compression
still having oil pressure issues at idle once its hot not sure what the deal is any ideas?
I am having similar issues with my oil pump. Did you re-use your old one or get a new one?
old oil pump that we took apart cleaned and resealed all the check valves were cleaned and lubed with assembly lube when put back into there proper place it didnt have this issue before which is what is puzzling me
What symptoms (what you see and what you hear) are indicators of low oil pressure at idle?
dont see or here anything aside from the idiot light on the dash it sounds fine and there are no leaks when its cold its not an issue as it gets warm and the thermostat opens it flickers then as after it gets to the optimum operating temp it stays on the second its off idle light turns off
both say that parts in the pump are sticking we had the no oil pressure at start up took the pump apart found what was sticking and fixed that issue it has oil pressure at start up and it has oil pressure off idle the light only comes on at idle when the engine is hot im still considering pulling the oil pump off yet again and go threw it all again
I'd check the clearance around the vanes with a feeler gauge. And maybe replace the springs in the check valves. check out this thread: http://www.ultimatesubaru.org/forum/topic/136455-1979-brat-4x4/
If that doesn't work you can always get one of these: http://www.ebay.com/itm/1972-1987-Subaru-1-6L-DL-GL-Brat-Engine-Oil-Pump-IN-STOCK-/290884640657?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1979%7CModel%3AGL%7CMake%3ASubaru&hash=item43ba135f91&vxp=mtr
I'm tempted to plunk down for one of those and call it good. $75 for a new oil pump is pretty good, esp. since the ones at o'reilly's and auto zone are going for $120 a piece! At least you know it isn't your mains causing the problem!
as for oil im running castrol gtx 10-30w same oil ive run in every vehicle i own but im thinking about stepping it up to 10-40w
thanks for the link ill read threw the thread but i would much rather fix what i got instead of buying a new one
looking at that thread i think that the new o ring that the rebuild kit came with is to thick and the clearances aren't right
Did you get an oil pump rebuild kit? I'm considering taking mine off tonight and having a look in there...
right on thanks for the pic man
i got the oil pressure issue squared away and now im just driving it to finish the break in
