November 14, 201114 yr I am looking for a set of 4 -14" steel rims to put a set of snow tires on them,I have called around to about 75 miles around me and I have no luck locating any.Can somebody tell me where to go look for a set?????or maybe a member is willing to sell some??????Will the 15" rims work on my car???Thank you all for the great site we have.Bill:banghead: Billn1ass@gmail.com
November 14, 201114 yr Checked your local craigslist site? Also try http://www.car-part.com. The classified section here is a good place to look too. You never know what you'll find.
November 15, 201114 yr +1, what he said. and 15" wheels will fit your car. you just have to make sure the tires are not too big. google ''tire size calculator'' and use it to finf equal size tires to your 14s. 195/60/15 is probably equal to your size.
November 15, 201114 yr Author I found 4 - 14" rims for $30.00 on craigslist.Now I can order my snow tires.Thanks for the help.Bill
November 15, 201114 yr Are they Subaru wheels? Did you check lug pattern and hub bore size? No point in buying wheels if they don't fit on the car.
November 15, 201114 yr Good point on the rim size! That era should have the 5 bolt holes @ 100mm. There are some other cars that might work like Chevy Cavaliers from that era. My friend has a Cavalier and needed new rear tires, so I gave him two of my old tires on the Subaru rims and he was able to just bolt them right up and go.
November 15, 201114 yr Are they Subaru wheels? Did you check lug pattern and hub bore size? No point in buying wheels if they don't fit on the car. Ask the owner what car (year and model) these wheels came from. Like said.....you need to know that they will fit your car. Otherwise you have wasted $30 and your time.
November 15, 201114 yr Author They came off a 1995 legacy wagon,I hope I am safe by buying them.:cool:
