BOSS 2" EA82 Lift Kits- $100!!!
2" OFF ROAD SUSPENSION LIFT KITS for EA82 cars
This is a bulletproof (literaly, I've tested it :brow:) 2" lift kit for Gen 3 (GL, DL, Loyale, etc.) wagons, coupes, and sedans. It installs in as little as 1 hour if you know what you are doing.
It will put extreme angles on you CV axles, so make sure you have good motor and transmission mounts and spare axles just in case. Camber will be very close to stock so you shouldn't see much different tire wear.
Go from stock:
To Ready to Rock:
Available in Safety Orange Gloss, Olive Green Flat, or unpainted bare steel. Comes with Grade 8 mounting hardware.
Outrageously priced at only $100 per kit!!!!! (plus shipping)
PM me or call me, Bill, at (509) 391-5903. Thanks!
-Bill
  • Replies 115
  • Views 49.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The Beast I Drive
    The Beast I Drive
    All lift kits are sold, none left. Thanks to everyone who bought one, I hope you enjoy them and they serve you well, and sorry to anyone who missed out. If I start making more I will let yall know. Th
  • The Beast I Drive
    The Beast I Drive
    I believe that when the suspension is in high mode it rides the same height as one that has springs instead of air struts, and when the suspension is in low mode it is actually 2" lower than a normal
  • if youre going through asmany axles as  you report, youre doing it wrong.  or youre getting crap parts. this thread is pretty dead as  well as these kits are no longer in production. lmk if you wanna
I've got one too, although mine came with the car when I bought it.
its about time i see a 2" lift w/o tabs in the back. mine slip on the pass side from time to time. it messes up my strut top. (i have a homebuilt lift, go figure). so.... how much for just some rears? is this price sticking around or just a special? i could prolly buy a whole kit when the man gives me back my taxes.
RV
RV
This is the every day amazing low price :brow:
I could do just the rears for $50
-Bill
Crawler Dan sent me this way and i like what i see... how much for shipping to 59825?
I use flat-rate shipping boxes, so I can ship anywhere in the country for $15.00.
-Bill
so all you need to do is bolt these up correct will you also need to extend the steering linkage
on a 2" lift there is no need to extend steering linkage, nor do you need to drop your diff/engine xmember/trans mounts. anything bigger than 2" and you need to do those things.
RV
^^^ What he said.
With this lift, you may or may not need to cut the rear bumb stops off. Other than that it will bolt right in. The front is kind of a b*tch though, but you don't have to modify anything.
-Bill
OOoooo... now I know what to spend my Christmas money on. :brow:
I have several of these ready to ship :burnout:
Make sure you specify what color you want, otherwise you'll get whatever color I send you :D
-Bill
  • 2 weeks later...
  • 3 weeks later...
Do want, Will be ordering before Jan 31st for free shipping :)
Send you a PM when I get paid to order.
PayPal? or what method of payment preferred?
Cash Ready to go.
Would like it in black.
Thanks
  • 4 weeks later...
Do you build 2 inch ea81 lifts?
My experience with suspension lifts on EA81s has not been good. The shorter axles in them are already at a sharper angle stock than in an EA82, and typically with a 2" lift the axles blow apart in fairly short order. You'd have to do a full lift with body blocks and all that.
-Bill
Ok thanks for the response. Just trying to make a little room for the 27s I put on my brat. LOL
you can't clear a 27" on a gen2 BRAT without a 4" lift.
You might as well cut away, cause a 2" still wont clear.
Or get a shorter tire. but you would need a 4" lift to clear a 27" with no cutting.
Edited by bheinen74
I cleared them with a 3"
I allready have them on it and the only rub if I turn really sharp so 2 is enough. its not going to be used for anything extreme I have a brat with a 6 inch lift for that and I'm going to put a 4 inch on the third brat I have.
my definition of clear = zero rub no matter what.
maybe my mistake is taking for other people definition of what they mean by clear.
  • 1 month later...
Bump to the top! I have 6 of these in bare steel ready to ship!!!! Still only $100!!!!! plus $20 shipping anywhere in the US.
BUY SOME!!!!!
-Bill
This topic is now closed to further replies.
