December 4, 201114 yr Hello, I'm new here and new to owning and working on subarus. I have a problem with my 88 wagon. This model has four headlights. My problem is when turn them on all running lights turn of and so does the instrument panel. I was told to check my ground wires so if anyone has a solution to this problem or also knows where the grounds are located on this car the help would be greatly appreciated. Thanks.
December 4, 201114 yr Welcome! That is a Bad Relay issue... I Kindly Suggest you to Read this Thread: http://www.ultimatesubaru.org/forum/showthread.php?t=90403 I Hope it will be Helpful. Kind Regards.
December 10, 201114 yr Author Yeah, it was the relays. Thanks for the help. For now it happens every time I turn the car on and I have to reach down and give'em a little tap. Where did you get the supplies to wire in the newer relays? I checked out a few local places with no luck. Any help would be great. Thanks.
December 10, 201114 yr Our Local (Honduran) Napa Stores and almost any other Auto parts Supply Stores has them. I Really preffer Bosch Brand over almost any other, I Kindly suggest you to Avoid Cheapo Chinese Relays and You'll be avoiding Future Troubles. You can also buy 'em online, even at Amazon: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dautomotive&field-keywords=bosch+relay+socket Kind Regards. Edited December 10, 201114 yr by Loyale 2.7 Turbo add the web link
