March 17, 200422 yr Finally getn round to tearing into the 4spd i got in the brat.....has no reverse.....Has anyone done this and if so are there any pointers that would be helpfull......also ive heard some things about a easy fix for the reverse problem (sticking in gear and clashing) anyone know anything about that........... Well i will keep ya all up to date on the progress and maybe get some pics....
March 17, 200422 yr They are not simple inside - get an FSM if you don't have one, as they aren't even easy to get apart. You'll need the procedure on it. I'm working on one right now - I'm just stuck at the moment cause I don't have the right socket to remove the "extension housing drive gear" in order to remove the transfer case.... GD
March 17, 200422 yr Author well right now i have enough materials covering the transmission that i shouldnt have a problem (dirvetrain class at wyotech)....whats this about a special tool.... Anyway im pretty good at puzzles so i think i will be able to get it apart.
March 18, 200422 yr Author well i riped er apart today and it wasnt even as hard as expected BUT you do need a 34 mm thin wall socket (not an impact socket) And what i found was beyond belief.....My reverse idler gear was completly gone, bout 4 teeth left.....Also i was missing a tooth off the the drive pinion.....and lastly im missing the three sincro keys for the 1-2 sincro...the instructer pretty much told me he was amazed that it still drove..... Lastly some info for people going to crack there tranny open. make sure you know where all the springs, ballbearings, and sprag bearings are in the transfercase. thats the only thing were there is a bunch of little peices. BTW i have access to numerious programs (mitchel transmissions and alldata) if anyone needs any info on it.......
March 19, 200422 yr Yeah - that 34mm thin wall socket is holding me up.... any literature you could provide me would be great! I've got it half apart on the floor of my garage right now. Too bad I didn't know - I was in Tillamook today oddly enough. GD
