scotte6 Posted January 11, 2012 Share Posted January 11, 2012 I am looking for the torque specs and the procedure for torquing the heads and intake. Tried searching but did not find anything for my specific engine. Thanks! Quote Link to comment Share on other sites More sharing options...
ocei77 Posted January 11, 2012 Share Posted January 11, 2012 Here.Title says 05 but is the same. http://www.bustedfingermotorsports.com/forums/viewtopic.php?f=18&t=210 Inside it says 04 but that is Euro date. O. Quote Link to comment Share on other sites More sharing options...
mdjdc Posted January 11, 2012 Share Posted January 11, 2012 Looking at the bolts they are numbered as follows: 3 1 5 6 2 4 The torque sequence is as follows 1. torque all bolts in sequence to 21 ft-lbs 2. torque all bolts in sequence to 51 ft-lbs 3. in reverse order loosen all bolts 180 degrees 4. do step three again 5. Torque bolts 1 and 2 to 25 ft-lbs 6. torque bolts 3 -6 to 11 ft-lbs 7. torque all bolts in sequence 90 degrees 8. torque sll bolts in sequence 90 degrees You are done. Hope that helps. Mike Quote Link to comment Share on other sites More sharing options...
