January 30, 201214 yr For a 1999 impezza, can a remote start be installed? Or is there an OE plug & play? Are there good & bad sytems? . My brother used to have a Corolla & the thing would malfunction, & keep him from starting. Leaving him stranded.
January 30, 201214 yr If you park in a attached garage, or ever will park in one, I have to strongly argue not to do this. The aftermarket ones can kill you. Imagine this, your car is parked in the attached garage, and somehow the button gets pressed or malfunctions starting the car, and then you don't wake up. They are bad in aftermarket form.
January 30, 201214 yr Ive used dei products, ie viper clifford python....., ive had no issues with them, but i did install them myself, with a lot of work involved, and are not plug and play, ive never had them turn on with out the button being pressed, but it can happen when its in your pocket, so when there in the garage, i turn the toggle switch off, so it cant start. But i dont park in garages often so not a biggie, but it is a very big concern. Other then that they do work great in the winter.
January 30, 201214 yr there are definitely good and bad systems. I have had the best luck with Directed Electronics alarms (Clifford, Viper, Python, etc) and the most experience installing in my own vehicles and customer vehicles. Stay away from Compustar alarms, I installed one in a friends truck and since the alarm can be put in to programming mode with the remote it makes it very easy to change settings while the remote is in your pocket. just my .02 If a remote start is installed correctly there is a switch that can be turned off to disable the remote start feature if you park in an enclosed area. But you have to remember to disable it. as for a OE plug and play for a 1999, No not that I know of, this has come recently with the can-bus driven systems in newer cars. Ben
January 30, 201214 yr Do you know that if a hacker hacked into the on-star system, or the Sync system, that hacker could autostart all the cars on the planet that run with that system? How many would die if they had parked in an attached garage. I will yank that system out of any car that had it. But, I am sure the system is secure, just like any Microsoft computer is entirely safe from hacking What, you can start your car from your smartfone? cool, anybody else can too with a little work. Cool right. And remember if the system malfunctions it will cause a no start or leave you stranded. Why take that chance. Hackers can just as easily do the cutoff and make your car not start too. Fun right. IF you buy a start system, research as much as possible, many many research hours to get one that is safe and has auto shutoff after 5 minutes, etc. Do not go for a el cheapo wal mart special or ebay special. Get something from a manufacturer who makes OEM ones. Sure, it will cost alot, but it may save a death. Edited January 30, 201214 yr by bheinen74
January 30, 201214 yr You also might consider a block heater. Your heat will not be instant upon start up, but much quicker than otherwise.
January 30, 201214 yr Do you know that if a hacker hacked into the on-star system, or the Sync system, that hacker could autostart all the cars on the planet that run with that system? How many would die if they had parked in an attached garage. I will yank that system out of any car that had it. But, I am sure the system is secure, just like any Microsoft computer is entirely safe from hacking What, you can start your car from your smartfone? cool, anybody else can too with a little work. Cool right. IF you buy a start system, research as much as possible, many many research hours to get one that is safe and has auto shutoff after 5 minutes, etc. Do not go for a el cheapo wal mart special or ebay special. Get something from a manufacturer who makes OEM ones. Sure, it will cost alot, but it may save a death. How will an "OEM" remote start not start from inside a building? I am failing to see how this option is obtained. I agree, DO NOT buy a cheap no name brand. The brand that I suggested can be setup in a variety of ways including using a smart phone to monitor, start, lock and unlock and depending on the installer can be done very safely. Ben
