ckicking noise upon decceleration? (newb)
1997 Subaru legacy sedan 5 speed. When I slow down in parking lots, or any where, moving under 30mph Ish, there's a clicking noise coming from underneath the shifter is what it sounds like but definitely not the Trannys. Any clue?
Does it change if you move the shifter back and forth?
Sometimes the linkage can get loose and rattle.
Also, another likely culprit is exhaust heat shield rattle. Take a pry bar or something and poke the exhaust heat shields to see if they're loose.
Other thing I've had cause this. The mount from the transmission to the exhaust. I've had it break off the exhaust and rattle really annoyingly at certain RPMs.
