electrolysis Posted February 27, 2012 Share Posted February 27, 2012 I just got an 88 xt6 and was wondering if the power steering was recalled that year Quote Link to comment Share on other sites More sharing options...
Turbone Posted February 27, 2012 Share Posted February 27, 2012 I dont think it was a recall, but there was a fix/remedy for something dealing with the steering (jumper wire from plug to unit). Doing a search over on the XT forum should get results. http://subaruxt.com/forum/viewforum.php Quote Link to comment Share on other sites More sharing options...
electrolysis Posted February 28, 2012 Author Share Posted February 28, 2012 Yeah i looked into it at a dealership and it already had the service done Quote Link to comment Share on other sites More sharing options...
MADD1 Posted February 28, 2012 Share Posted February 28, 2012 Here's a Cool Link to find any recalls on any vehicle: http://www.alldatadiy.com/recalls/index.html Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 28, 2012 Share Posted February 28, 2012 Yes, there was a recall but no, you're car is now too old for it to be done. The symptoms are the steering light coming on randomly and loss of steering assist. The recall is to replace the steering signal controller, power controller and a couple harness adapters for them. The recall lasted for 20 years and I found out my '89 hadn't been done but when I called SOA, they couldn't locate anymore of the recall kits, even though I believe they are required to fix it. I'm just trying to find the parts on another vehicle so I can do the recall on it myself but haven't had any luck yet... Quote Link to comment Share on other sites More sharing options...
themoneypit Posted February 29, 2012 Share Posted February 29, 2012 usually on these if your having troubles with the steering, a new set of brushes for the electric motor are needed. they are pretty easy to do, and there is a great write up, with pictures, in the tech info thread on subaruxt.com/forum they even have the subaru part numbers for the brushes you need. Quote Link to comment Share on other sites More sharing options...
electrolysis Posted March 1, 2012 Author Share Posted March 1, 2012 Is the reservoir for the master cylinder the same as an ea82? I need to replace just the reservoir and reuse the master cylinder... and how easy is it to remove the reservoir from the master??? Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted March 2, 2012 Share Posted March 2, 2012 Don't see why it would be. It should be a tight fit using a rubber grommet which will probably be unusable once you pull it out. Sometimes they can be reused but with age, they can become fragile. Quote Link to comment Share on other sites More sharing options...
electrolysis Posted March 2, 2012 Author Share Posted March 2, 2012 So i tried that... and it worked good so far. the gromet wasn't too dried or brittle. and i almost got it running Quote Link to comment Share on other sites More sharing options...
