Unsp0kn Posted March 7, 2012 Share Posted March 7, 2012 I did a little bit of reading on the site and I want to take my ignition apart and re-route the wires to switches on the dash for my RX rally project car. Right now it starts just fine, but turning the key off does not shut the engine off. Could I pretty easily put a switch off the existing wires to kill the engine? I want to do a setup to have one switch to turn on the ACC power and another momentary switch for the push button start in the future along with the killswitch to shut the engine off. I'm just not sure which wires are what and if it would be a good idea to use the ones off the factory switch. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 7, 2012 Share Posted March 7, 2012 Don't. A replacement ignition switch is about $35 from the dealer. You will just end up making a mess of things. If you have to ask how to do it you aren't ready to do it properly. Trust me I do a lot of electrical work because of silly notions like that one. GD Quote Link to comment Share on other sites More sharing options...
Unsp0kn Posted March 7, 2012 Author Share Posted March 7, 2012 (edited) I'd rather spend $9 on some switches than buy a new ignition switch. This car is offroad only and will only be used for RallyX. As of now the switch doesn't shut the car off and I don't want to have to stall it all the time, so I want a switch to shut it down and figured I would do the momentary switch for the starter. Same thing the key does, just with 25amp toggle switches and 25amp momentary. I work for a company that manufactures electronics, I'm more than capable of soldering some wires and putting some switches in place. All I asked were what wires on the ignition switch were which, but thanks for giving the standard "don't" answer. I think I figured out which wires were which anyways. I'll report back when it works. Edited March 7, 2012 by Unsp0kn Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted March 8, 2012 Share Posted March 8, 2012 If you work with electronics then figureing out the wires should be no trouble at all. All you need is a meter or a diagram. It's a whole 5 wires you are dealing with. You will need a DPST switch - they sell key switches for this purpose - and obviously a push-button. You should use relays to control the actual current switching so the pushbutton doesn't take the full starter current and the toggle switch can be much smaller and nicer looking. It's still a stupid idea though. $5 will get you a used ignition switch from the junk yard. They rarely fail..... you also haven't determined if the switch is even the problem. Thus your toggle switch may not even function to turn it off. GD Quote Link to comment Share on other sites More sharing options...
l75eya Posted March 8, 2012 Share Posted March 8, 2012 It's too easy to jump right off the bat and say no don't do it. However it's too difficult to jump right off the bat and say go for it; If you are comfortable with wiring, and have confidence in yourself and your ability, go for it. As for the things you are asking, do yourself a quick favor and go to ebay and get yourself one of the chilton's or Haynes manuals for the car. If you want, I have a FSM I could email you. PM me if you'd like. I do recommend getting the service manuals though as they're a-lot more reader friendly and they do have thorough wiring diagrams. At any rate, however, good luck with it! Quote Link to comment Share on other sites More sharing options...
Unsp0kn Posted March 8, 2012 Author Share Posted March 8, 2012 Well I got it figured out, 1 toggle switch for accessory power, 1 run and a momentary toggle switch for the ignition, so it basically does what the oem ignition switche used to do, just 3 separate toggles. All wired up and now I can finally shut the car off with the switches instead of stalling it. It might be stupid to you, but I don't need a key for this car, it's a rallyX car only, not going to be street driven at all plus it accomplished what I wanted. Quote Link to comment Share on other sites More sharing options...
l75eya Posted March 8, 2012 Share Posted March 8, 2012 Glad you were able to find a solution to your issue! That's what it's all about, anyway haha Quote Link to comment Share on other sites More sharing options...
MilesFox Posted March 9, 2012 Share Posted March 9, 2012 If this thread had a "like" button, i just clicked it. Quote Link to comment Share on other sites More sharing options...
