dead 2.0 s
ending up with a pile of dead 2.0 l engines seem to be a bitt weak have heads botom ends colecting cores but i dont use the 2.0 moters just two small what should i do with them ?
no all turbo ones one with bad rod one with melted piston one shop tore apart to fix lifter and couldent figure out how to put back together and some that are a ? whats wrong with them i only use the 2.2 or 2.5 dont like the 2.0 at all
It is a documented fact that the EJ20 engines have problems with oiling to the rod bearings. Even the cross-drilled cranks haven't really solved the issue.
If you weren't in Canada, I might buy a couple decent ones from you.
i know dam canada i have so many parts and dont know how to market them to usa
