"Ghost Walking"
Sorry for the lack of clarity in this picture, its hard to get a good pic in that area. From what I can tell this is where the upper link attaches to the rear arm.
  • Replies 52
  • Views 25.7k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Your cavalier boastery is foolishly ignorant.  Sounds like your the one that is refusing to "grow up" and face the rules of the road.......like adults with the privilege of driving all have to do.  Yo
  • brus brother
    brus brother
    Last winter I experienced horrendous handling in my 05 OB and at first I thought the ghost had taken up residence in my car. Turns out the alignment was way off. The four corners of the car were figh
  • Its not going to be fixed as long as they still use the same multi-link rear suspension design they started using in 05.    Pre-05 models don't have this problem because the rear suspension is a sim
Posted Images
00-04 outbacks are the same in this regard, here's a diagram which should show the hardware you'll need as well - bolts/washer/nut which often need cut off.
https://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=2003&modelName=legacy25l-at-4wdoutback-wagon&ukey_assembly=6029084&ukey_category=54106&assembly=b12-201-02
I replaced the left and right upper links and it improved the ride quite a bit, on the right link the outside mount was quite worn, on the left it was the inside. I am attaching a picture of the left link and a closeup of the worn mount. This job was easier than I anticipated with the wheel removed you don't even have to crawl under the car. 1660253286_leftupperlink.thumb.jpg.f23f55a0758c2ba6e133c3560cd2e8ba.jpg
