wilcox Posted April 9, 2012 Share Posted April 9, 2012 ok! so i have an 85' wagon with the origonal hitachi carb on it. its an ea82 and i want to put a weber on it. what are the the benefits and how do i do it? thanks Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted April 9, 2012 Share Posted April 9, 2012 Welcome! Probably the second most ask question on this board. Use the search function and you will find 100s of pages on the subject. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted April 9, 2012 Share Posted April 9, 2012 ...or Click on my Avatar and Scroll Down to Reach my Writeups List; there You'll Find a Link for the one about the Weber Swap on Carbureted EA82 Engines. Kind Regards. Quote Link to comment Share on other sites More sharing options...
wilcox Posted April 9, 2012 Author Share Posted April 9, 2012 iaght will do!! thanks Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 11, 2012 Author Share Posted May 11, 2012 how should i jet my weber, i have examples from other threads but im not sure about my elevation witch is about 3500 feet above sea level. thanks Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 11, 2012 Share Posted May 11, 2012 I really Believe that you must Check How are the Jettings in the Carb Right Now, Before installing it; because the Weber that you obtained, was Jetted for another Car's engine... However, the Main Jets on the Weber Conversion Kit from Redline, Designed to be used on the EA82 engine, comes with Both Jets as 140 (Same Low & High) but I Switched the High one to 162 after Many Tests. I Drive between the Sea Level and 3,000 Feet around without issues, I Believe that you Might use the Weber with Both 140 or Less due to more Higher Altitudes. Kind Regards. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 12, 2012 Author Share Posted May 12, 2012 ya right now the fuel jets are both 140 with 170, and 190 air corrector jets, and the idle jets are fifty i think i might bump the secondary fuel up to 145 and run like 200 and 210 air corrector jets. but im not sure. how much timing are your running base, and did you change your mechanical advance at all? thanks Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 12, 2012 Author Share Posted May 12, 2012 also what are your air corrector jets? because i think those are the only ones needed for altitude difference. thanks Quote Link to comment Share on other sites More sharing options...
hanyou Posted May 12, 2012 Share Posted May 12, 2012 It would probably be beneficial to post make a sticky showing the procedure.. many of the old threads merely reference the other threads or have pictures that are broken links. The USMB guide isnt bad but the pictures arent close enough/detailed enough. Just my 2 cents.. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 12, 2012 Share Posted May 12, 2012 I Changed the Vacuum Advance with a Single Port One, and my BumbleBeast Runs with the Ignition Timing at 20º. It would probably be beneficial to post make a sticky showing the procedure... Here it is: ~► http://www.ultimatesubaru.org/forum/showthread.php?t=74206 Full of Fully Working Photos and Explained Procedures. I Hope that could Help. Kind Regards. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 12, 2012 Author Share Posted May 12, 2012 ok so what is your whole jet set up, i know your running 140, and 162 fuel jets, but what about the air correctors and idle jets. im asking because im going to use your set up but change if for my elevation requirements. thanks Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 13, 2012 Share Posted May 13, 2012 I Never touched the Air Jets, so they are as they came Factory in the Redline's Weber Conversion Kit for the EA82. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 13, 2012 Share Posted May 13, 2012 ... im going to use your set up but change if for my elevation requirements... Could I Ask you Why don't you Try to Drive the Car with the Weber Swap done First and Then, you'll Notice if the Carb will (or Not) Need any correction? Kind Regards. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 14, 2012 Author Share Posted May 14, 2012 Could I Ask you Why don't you Try to Drive the Car with the Weber Swap done First and Then, you'll Notice if the Carb will (or Not) Need any correction? Kind Regards. because it is easier in my mind to take all the information i know (what other people have it jetted at, stock jetting, and the craptachi jetting) and make an educated guess as where to start. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 14, 2012 Author Share Posted May 14, 2012 right now i have it jetted: primary idle 55, secondary idle 45, primary air corrector 180, secondary 190, primary fuel 40, secondary fuel 45. i would run a bigger secondary fuel jet but that is the biggest one i get with my jet kit Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 15, 2012 Author Share Posted May 15, 2012 ok so on the fuel side of the craptachi carb are two hoses, one is fuel and what is the other, they are right next to each other. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 15, 2012 Author Share Posted May 15, 2012 also what is the best way to seal that coolant passage on the intake? Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted May 15, 2012 Share Posted May 15, 2012 Its all in this write up. If you read it you would have your answers. Also if you search you will find hundreds of threads on the swap. EA81 and EA82 swaps are about the same. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 15, 2012 Author Share Posted May 15, 2012 no, that write up only answere some of them ( ive read it like 9 times ) and the search bar makes it difficult to find what i need to know, but ill try. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 16, 2012 Share Posted May 16, 2012 also what is the best way to seal that coolant passage on the intake? After Reading this, I Hardly Believe that you Really READED it... I Used Aluminium Welding to Fill the Water Passage, as that thread Describes that plenty of Pictures, but you can use whatever you Want, like JB Weld, made a Thread in the Tiny opening and insert a Screw then cuttin' its head to close it, etc... Kind Regards. Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 16, 2012 Author Share Posted May 16, 2012 i also had throttle cable length problems Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted May 17, 2012 Share Posted May 17, 2012 You'll have them if the Carburetor didn't came with The Accelerator Cable Bracket... then you must search for one. Good Luck! Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 18, 2012 Author Share Posted May 18, 2012 i just modified the hitatchi linkage, ill post pics when im all done Quote Link to comment Share on other sites More sharing options...
wilcox Posted May 18, 2012 Author Share Posted May 18, 2012 why is the fuel return line from the float bowl to the tank smaller than the fuel in line? Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 12, 2015 Share Posted November 12, 2015 why is the fuel return line from the float bowl to the tank smaller than the fuel in line? The idea is to maintain the proper fuel Pressure at the Carburetor, otherwise, the fuel will return to the Tank, faster than the amount needed by the Carburetor, during deep accelerations... i just modified the hitatchi linkage, ill post pics when im all done so, where are the Photos? Kind Regards. Quote Link to comment Share on other sites More sharing options...
