4wd light issues
My 4wd light is always on in my Brat as well:
2wd= 4wd light on
4wd hi = 4wd light on
4wd lo = 4wd & lo light on
I've heard it is a little sensor on the 4wd lever that gets stuck.
Someone else should elaborate on this, I'm looking for a fix as well. :D
2wd= 4wd light on
I'll try to find that sensor and see if i can do something with it zzz
The sensor switch is bolted to the floor under the console by the hi-lo lever. Mine had the little plastic piece break off the switch when I was messing with the shifter a while ago, now the 4WD light stays on all the time. I'm pretty sure I saw the entire part on Rockauto.com for $12.03
http://www.rockauto.com/catalog/x,carcode,1267725,parttype,10775
I'm gonna start tearing more into it this weekend and hopefully It'll be simple fix :grin: and it's weird how it's not listed under 86 :-\
It's the top part listed... mine is busted too. Easy to get to, cheap fix.
I fixed mine on my Old 85 Hatch with 3 small zip ties and one Wire thingy off a loaf of wonder bread and a little squirt of Electode Spray cleaner.
the plunger was broke when i put a screwdriver in it the 4wd light came off. Does this one switch control the 4w lo and 4w hi light to?
Edited by scubasteve7196
