abs, airbag, no radio
what would cause the airbag light, abs, and radio not working after sitting a month .95, thinking it is a fuse,
Edited by 86subaru
added notes
Did you jumpstart it? If so, any chance the cables got hooked up backwards?
I'll admit to having done this. It took out the internal fuses of my stereo, my CB, and my inverter. I'm glad it didn't affect my ECU.
Just a wild guess.....you didn't really give us much info to go on.:confused:
just bought it abs , air bag radio works but power antenna does not go up , check fuses all seem good ,any help ?seller said did not jump start , but had set a few months, 95 awd a/t 2 door impza
for the power antenna - you may want to check the wires back at the antenna itself - mine had corroded (wisconsin car - rusty wheel wells) to the point that it wasnt getting power anymore - fixed that, and it now works fine.
as for the other stuff, definietly check fuses - I know that pulling the fuse for the ABS on my car turned the light in the dash on (fuse #10 I think, may be different on your 95 Imp)
there are also fuses for ABS in the box under the hood.
I dont have airbag on mine (90 Legacy), so not sure about that one, but would definitely start by checking fuses.
pulled antenna all the way up , checked all fuses all good, abs and air bag light on ?
