Suba_GL_87 Posted June 1, 2012 Share Posted June 1, 2012 i was repair pair of head gasket (Becky) on ea82 loyal. so, it's was running good and i was drove around 10 miles and there have a temp's gauge going climb-up to overheating...the muffler became blow out! Even coolant box was broil out also radiator too. does I got a mistake torque head? 25, 46 AND 52 FT LB. OR need repair Thermostat or new bolts or what? manifold gasket is good.... but whats wrong is?? Quote Link to comment Share on other sites More sharing options...
Stubies Subie Posted June 1, 2012 Share Posted June 1, 2012 if I understand your post correctly, your saying you installed new head gaskets, got it running good, drove it about 10 miles, it over heated and you had boiling coolant coming out of the muffler as well as the over flow and the radiator? if that's what your saying, something went wrong with your head gasket Job. or you didn't replace all that was wrong with it. in my opinion, if your doing head gaskets because of over heating problems, you should probably also replace the radiator and thermostat, (Thermostat should be dealer only) the old radiators in the EA82's are marginal at best for cooling, and are easily plugged up over time. if I had to do head gaskets over again, I'd also replace the radiator, thermostat, and water pump. just my opinion, others may differ. i was repair pair of head gasket (Becky) on ea82 loyal. so, it's was running good and i was drove around 10 miles and there have a temp's gauge going climb-up to overheating...the muffler became blow out! Even coolant box was broil out also radiator too. does I got a mistake torque head? 25, 46 AND 52 FT LB. OR need repair Thermostat or new bolts or what? manifold gasket is good.... but whats wrong is?? Quote Link to comment Share on other sites More sharing options...
nipper Posted June 1, 2012 Share Posted June 1, 2012 What prep work was done to the heads befopre the engine was reassembled? Quote Link to comment Share on other sites More sharing options...
Stubies Subie Posted June 1, 2012 Share Posted June 1, 2012 What prep work was done to the heads befopre the engine was reassembled? good point, heads need to be resurfaced when doing head gaskets Quote Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 2, 2012 Author Share Posted June 2, 2012 yea, i did perfectly resurfaced and smoothly before installed. i think head gasket just failure or thermostat. water pump is good bearing and there good spring. but i can tell it's old, so whats is different? i will show my youtube for EA82 on this weekend. 8) Quote Link to comment Share on other sites More sharing options...
nipper Posted June 2, 2012 Share Posted June 2, 2012 Before diging into everything, lets get a wet and dry compression test to see what is going on. Was there coolant in the over flow tank (I think this has one?) after the car cooled down Quote Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 2, 2012 Author Share Posted June 2, 2012 yeah, coolant over the flow. when car cool down and could start again but will overheat again. Before diging into everything, lets get a wet and dry compression test to see what is going on. Was there coolant in the over flow tank (I think this has one?) after the car cooled down Quote Link to comment Share on other sites More sharing options...
nipper Posted June 2, 2012 Share Posted June 2, 2012 Ok just wanted to see if it was getting burned or blown out. What color is your oil? Quote Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 3, 2012 Author Share Posted June 3, 2012 burn and stop and burn, stop and burn again became white smoke whole thing after 10 min driving. also temp gauge gone to overheat. Ok just wanted to see if it was getting burned or blown out. What color is your oil? Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted June 3, 2012 Share Posted June 3, 2012 At this point your probably better off getting another used engine that is running and known to be good. Engine swap is easier then head gasket job. Quote Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 3, 2012 Author Share Posted June 3, 2012 but last time i was drove pretty good and i decide to repair head gasket because of there was bad lacky by oil.. At this point your probably better off getting another used engine that is running and known to be good. Engine swap is easier then head gasket job. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted June 3, 2012 Share Posted June 3, 2012 but last time i was drove pretty good and i decide to repair head gasket because of there was bad lacky by oil.. So it had lack of oil and extreme over heating recently. Probably best to swap engines at this point. Quote Link to comment Share on other sites More sharing options...
Suba_GL_87 Posted June 3, 2012 Author Share Posted June 3, 2012 end of thread. head gasket had melt it before i pour coolant. So it had lack of oil and extreme over heating recently. Probably best to swap engines at this point. Quote Link to comment Share on other sites More sharing options...
