June 26, 201213 yr I have a 2.2 and want to do a gasket job wheres the place to get all he gaskets I need? it has a blown head gasket,
June 26, 201213 yr What year 2.2? Phase 1 2.2 gaskets felpro makes, it's the same part you would get at a dealer. Autozone carries them for 19.99 each.
June 26, 201213 yr Subaru would be a good idea for these - or Fel Pro's that are identical. But the 2.2's don't blow headdgaskets so they are much more forgiving than the EJ25s and I wouldn't squirm at using something else. EJ22's don't blow headgaskets so they usually have been previously overheated which *causes* the headgasket to fail (clogged radiator, leak, etc). seeing melted timing covers or bearing issues on those is not uncommon so keep your eyes out for issues as you go along. good luck SJR
