August 7, 201213 yr I had to do some work on my loyale recently which involved removing the timing belts. I reinstalled them and went to set the timing, but can't get it better than 18* BTDC even after redoing it to check that I wasn't 1 tooth off. I probably still am 1 tooth off. Are ther any issues or foreseeable problems with running the engine this way other than obvious performance losses?
August 7, 201213 yr is it pinging? i drove mine for awhile like that before i decided to time it correctly. did it like it? no. even less power? yes. permanent damage? none that i can tell. id fix it tho, its not that hard and these things are slow enough to begin with.
August 7, 201213 yr Author Ya, it's got a little ping. It's been a project for so long that I just want to drive it. I think I may wait to fix it for now.
August 7, 201213 yr drive it up to tacoma, ill do it for you. then you can drive it and i get a cold beer, and your car will be happy lol. win win win
August 7, 201213 yr If you're at the end of the slot for timing the disty, someone may have had the disty out and installed it a tooth or two off. Mines that way, at the end of the slot. Just,, made 20* BTDC. Plan is to reset disty, but not right now. Got other issues to adress 1st.
August 8, 201213 yr Ya, it's got a little ping. It's been a project for so long that I just want to drive it. I think I may wait to fix it for now. If it's pinging it's not that fun to drive, down on power, and real potential for damage to the motor. At least put premiuem fuel in it. If it's pinging it will run hotter too and could possibly take out a head gasket... Doug
August 8, 201213 yr Author It's not really a "ping", more of a "tick" or a "tap" I am assuming that would be a ping from improper detonation. Am I wrong?
August 8, 201213 yr Author drive it up to tacoma, ill do it for you. then you can drive it and i get a cold beer, and your car will be happy lol. win win win Hell of an idea. If I'm ever up that way I'll give you a buzz.
