85' GL wagon, rear sus. Adjustment?
I was looking to see if the rear suspension could be adjusted on my 85' gl wagon, and couldn't see where I'd do it.
Anyone know where the adjustment is? I figured out the front end, but the back has got me stumped. It's probably obvious, but It's probably been caked over with mud under the fenderwells.
Thanks,
Aaron
at the bottom of the shock, there is an adjusting cam you turn AFTER the coil spring is compresed
where is the front adjuster?
