need to know what to look for..
i've been around awhile on the old gen side.. never owned a new gen car.. but i found a 92 legacy L sedan.. Automatic, 2.2L engine.. now i know the 2.2's are bulletproof and the most reliable engine subaru ever made.. this car has 165k body and paint are very nice, interior is also nice.. a couple things don't work like the drivers side seatbelt and door lock, and the power window switch is broke.. fiarly new tires too.. don't know if its AWD, i need to look for the rear diff tomorrow too..
now the other stuff.. the car has a stripped out plug hole on #4.. we started it and it fired right up even without that plug.. any opinions on helicoiling it?
anything thats not obvious that i need to check for when i go back to check it out again tomorrow ?
Welcome to the world of legacies!!
Well I have also just joined the new ranks after owning 10 other subarus from 1976-1989. I recently acquired a 91 LS Wagon AWD. I would look for oil pump leaks, possible warped rotors and make sure the auto seat belts are repairable.
Gongrates and welcome aboard!!
in a beater. I think I changed plugs two times more in the time I owned it.
The tough part woould be room to work without pulling the head on one of these.
I would ditch those seatbelts and install something from another car if I owned one of those . I hate them. Just be sure to mount the seatbelts in a spot the factory has engineered for it.
Odds are all the old gen guys will get here eventually. It's kind of like having your hair fall out.
Not a chance if subaru keeps up the way they have been going.. Bring back the EJ22 and EJ22T and you are more likely to find me here.
QUOTE]
How can you convert from the motorized seat belts?
I would love to get rid of mine.
brands.
I am sure someone from the board can step in with specific knowledge.
Usually car body types are used for a number of years in many configurations.
What I did on a Mercury several years back was go to a junk yard and match up the closest ford product that did not use the auto choke belts.
I pulled the whole system from that car and mounted the belts exactly the same as they came from the donor.
If I recall I had to put a small amount of braceing under the belt area to mimic the donor car.
It was actually more trounble to get the old system out and find a similar color piece to cover where the moving rail had been.
This is the kind of thing that could be a liabilty issue so not many mechanic would do it for a customer.
The high dollar way is to contact a racing belt manufactuer.
other things to check
(i didnt read the whole thread so I might repeat something)
head gaskets
timing belt(should have been replaced already, if not should be first on your list)
any oil leaks
