egr pipe size
yep 17mm and I might need to use heat on it.. used a flare wrench.. used channel locks to turn.. still wont move.. however having said that trying to get the pipe off the head would be a bit odd.
Remove the EGR valve and gasket.
Use two nuts. The 12's that came off will work.
Use a wrench on the inner jam nut and you can turn the stud out.
This will give you room to use either vise grips or a small pipe wrench.
PB the copper pipe well .
This won't strip the nut and gives you the oomph to pop it loose.
Heat won't hurt, but I had to resort to the above method to get mine off.
Didn't have to remove the bottom one in my sitaution, but I'll cross that bridge when I get to it.
O.
Thanks will have to try that one if my issue returns.
