Dj Syco Posted February 6, 2013 Share Posted February 6, 2013 So I thought the sender was broken, turns out its just not plugged in! problem is, I have no idea where the body harness is!! Instead of spending a lot of time pulling the tank and all I'd rather just re-wire it into the cluster myself. does anyone on here know what goes where on the plug??? Quote Link to comment Share on other sites More sharing options...
skishop69 Posted February 6, 2013 Share Posted February 6, 2013 Dude, it's like 15 minutes to lower the tank to plug it in. Put a 2x4 on a jack and put it under the tank. remove the bolts only, not the lines. Slowly lower it until you have enough room to reach in and plug it in. Reassemble. Hella faster than a rewire. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted February 6, 2013 Share Posted February 6, 2013 The harness originates from the passenger side storage hold in the rear quarter. There is a metal shield. The terminal comes through a grommet. The wire may just be pulled up into the body. You should not have to drop the tank as long as the pigtail form the sender is present. This panel is where all the vent connections go. There are 6 bolts to drop the tank. You would probably have discovered the wire you were looking for once you got to this point. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted February 6, 2013 Share Posted February 6, 2013 in the back under the cardbord pullout on the ps side right by were the filler go's in is a meatal cover with 3 screws pull this cover and you will see the conector for the gauge it likes to corode in thiss spot have repaired many do not have to drop tank. Thiss is on the inside bottom ps side at front of pocket check here first Quote Link to comment Share on other sites More sharing options...
rdweninger Posted February 6, 2013 Share Posted February 6, 2013 I just fixed my fuel gauge sending unit (potentiometer) on my '85 EA82 carbed, analog gauges. I had to pull up the carpet in the rear of the wagon - passenger side. Then you will see the 3 screws for the cover. Then remove the screws holding the sending unit into the tank to repair the potentiometer... or just clean the wire connections first. Quote Link to comment Share on other sites More sharing options...
Dj Syco Posted February 7, 2013 Author Share Posted February 7, 2013 you guys are amazing. Will report back with findings/fixings. Quote Link to comment Share on other sites More sharing options...
