some help pls
hi all i have vw beetle bug water cooled i wont ask  subaru ea82 engine temperature must be i dont have the orignal gauges i have dafi gauge it read 90 : 92 c and when it up to 93 :95 c the fan is start to work to get it to 90  is it good and what the engine  temperature must be in normal and another proplem will see in the photo
and under the engine i have some thing i dont no what is must connect with its only thing under the engine what is it i didnt see pic to engine  in INTERNET have it i see it ploged it behind oil pan and exhaust
Hi, are you saying that you have a VW with a SUBARU EA82 engine?
Well, I've seen many Subaru Conversions on VW's ...
... Beetle, Carmann Ghia, and Vanagon, there's even a Forum in USMB about those,
Here: ~► http://www.ultimatesubaru.org/forum/forum/29-vanagon-conversion-discussion/
But I'll Like to See Photos of your EA82 engined Bug.
The Thermo Switch on the Radiator of the Non-Turbo EA82 is Designed to Open (turn On) when temperature reaches 203º F (95º C) and it Closes (Shuts Off) when Temperature Downs to 194º F (90º C)
More info on this Thread, ~► Here.
Kind Regards.
Loyale..thanks for the info...I have seen Subaru engines in VW's...am also soon acquring a Vanagon Syncro..thinking of a Subar Conversion too.
thanks alot now my engine temperature in good but u miss the pic it have some problem ples see the pic and tell me what i do
Edited by kasper_t11
The engine you posted first and the second one are not the same fuel system. First one is carbureted nd second one is fuel injected.
Also the second picture I can barely make out any of the writing on it.
There is only one breather on either side and they get connected and plumbed into the intake after the air flow sensor.
