June 22, 201312 yr I am swapping a 5spd dual range tranny into my Loyale and the shift linkage I have does not have any bushings. Does anyone know where to get new ones? Or what fits? It's the bushings where it connects to the tranny at the end of the linkage arms.
June 22, 201312 yr AFAIK, that's a dealer item. Or you do the McGyver fix: http://www.ultimatesubaru.org/forum/topic/122888-tech-tip-ea81-4-speed-sloppy-shifter-bushing-fix/
June 22, 201312 yr Author Hmm. I'll have to ask the dealer. This is a 5spd, not sure if it's the same as 4spd. Also, I have no bushings at all in mine, someone removed them completely.
June 22, 201312 yr Author They are the ones that are on the sifter linkage where it attaches to the tranny. I'll get a picture later and post it up!
June 23, 201312 yr Ok... Have 1 set of the big-end bushings, used but still in great shape. Good small-end bushings that refuse to come out of the shifter. Working on remedy to that.
June 28, 201312 yr Not going to possibly destroy the bushings by trying to remove them. Seems the center tube has become one with the bushings and doesn't want to let go easily. Not going to force it. I can send you the whole arm if you want, along with the big-end bushings.
