So, a month to so ago, my heater started making a noise: not so bad on low, but quite loud on high. Definitely louder and more of a problem the faster the motor is going-- but heat and a/c still work. In the past week, however, there is most definitely a dead animal smell coming from the vents-- only really bad when the car is on. Help? Suggestions?
Remove the glove box. That will provide access to both the blower motor and to the resistor pack. By removing both, you will have access to the intake path, and a good view of the evaporator core. Hopefully that will be enough to identify and correct the problem. By the way, shouldn't a '03 model have a HVAC filter? If there is one installed, just pull it out, and you'll find your answer.
Edited by avk
