September 2, 201312 yr How much oil should I put in my 1990 loyale with 314 thousand miles? I have never changed it
September 2, 201312 yr Not sure. Fill 'er up while checking the dipstick periodically. Once it hits the full mark, run the engine for a few minutes then re-check - make sure it's still at "Full" Voila.
September 2, 201312 yr Not sure. Fill 'er up while checking the dipstick periodically. Once it hits the full mark, run the engine for a few minutes then re-check - make sure it's still at "Full" Voila. If you're not sure, please research and then post your findings!
