squatty Posted September 13, 2013 Share Posted September 13, 2013 The odometer in my daughter's '95 Impreza stopped working and I'm thinking I should try and replace the gauge cluster. I believe the legacy cluster will swap in fine and they are much easier to find in the junk yards. I've read through what I can find using the search but I was wondering if anyone has experience replacing an impreza cluster with a legacy cluster. I'll start by searching for the same year Legacys and Imprezas. Link to comment Share on other sites More sharing options...
Legacy777 Posted September 15, 2013 Share Posted September 15, 2013 Does the speedometer still work? The odometer and speedo are one integrated unit. So if one works and the other doesn't some of the plastic gears in the odometer might have broke. There are subtle enough differences in the shape of the gauge cluster, plus different wiring that would make swapping the clusters prohibitive IMO. If the speedo does not work, then I would check the cable. Is her Impreza an auto or manual? If auto, the base piece that screws into the transmission where the cable attaches is common failure point. They are pretty easy and cheap to replace. Here's a pic of it. www.main.experiencetherave.com/subaru/images/speedocablebase.jpg Link to comment Share on other sites More sharing options...
squatty Posted September 25, 2013 Author Share Posted September 25, 2013 Thank you for the reply. My daughter's car is an automatic and the speedometer was still working. I wa actually able to find an Impreza cluster of the same year! I replaced it and the speedometer and odometer are both working. Now I just have to take it back out in the morning and figure out why half of the lights are not working. Link to comment Share on other sites More sharing options...
lmdew Posted September 25, 2013 Share Posted September 25, 2013 Bulbs burnt out. Easy to swap them from one to the other. Link to comment Share on other sites More sharing options...
ivans imports Posted September 25, 2013 Share Posted September 25, 2013 give the top of dash a wack above gauge cluster this should bring the lights back on Link to comment Share on other sites More sharing options...
