subi dude Posted October 13, 2013 Share Posted October 13, 2013 I am in need to know if I can change my rear CV axle by myself and not have a shop do anything? what has been happening is the inside of the CV axle(the big round part that flexes), has been making all kinds of snapping sounds and is LITERALY starting to seize up and making the car almost stop!! Has this happened to any of you? and am I going to be able to fix it? I already have the new axle and plenty of tools. I have changed the front axles before but never the rear. please let me know if you any information. thanks, Austin Quote Link to comment Share on other sites More sharing options...
AKghandi Posted October 14, 2013 Share Posted October 14, 2013 it should be pretty straight forward, theres a roll pin on both ends of the axle, and you may need to lower the rear diff mustache bar. you my run into problems with the axle coming off the stub shaft and the diff stub they tend to be pretty comfy where they are and not happy about moving. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 14, 2013 Share Posted October 14, 2013 If the wheel is seizing up, the problem is probably rthe whee bearing. This requires a special pin socket and a press. Perhaps remove the trailing arm and take it into the shop and have them press in the bearing for you. You will save labor if yhey re not removing it from the car. You will need a 3/16" punch for the roll pin, and 14mm and 7mm tools. Quote Link to comment Share on other sites More sharing options...
scoobiedubie Posted October 15, 2013 Share Posted October 15, 2013 Rear is easier than the front. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 15, 2013 Share Posted October 15, 2013 Rear is easier than the front. hmmm, can't exactly do it with a drift and a hammer, good luck without the socket, and forget it if there is rust. 1 Quote Link to comment Share on other sites More sharing options...
wagonist Posted October 15, 2013 Share Posted October 15, 2013 agreed with the above. The rears are held in with a pin either end instead of going through the hub. knock out the pins jack up the car leave the wheel on, then undo the bolt holding the strut to the suspension arm they get lots of dirt & rust into the splines so be ready to use lots of lubricating spray and/or heat on the CV joint put weight on the wheel downwards and the arm should move enough to allow the CV to get clear of the splines. Before you go changing the CVs, now spin the wheel and you should get a feeling of how good/bad the wheel bearing is. If you really have to, you can leave the rear axles out (by locking the centre diff on full-time-4wd models manual gearbox, or putting in the "FWD" fuse for full-time 4wd autos) Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 15, 2013 Share Posted October 15, 2013 Don't forget to lube up the splines with some grease BEFORE you put the new axle on. Quote Link to comment Share on other sites More sharing options...
