December 2, 201312 yr 92 loyale and my 4x4x won;t engage when it press the button. recently i replaced the clutch and right after that it stopped working... thought on if that caused it to stop working?thanks!
December 2, 201312 yr Check your vacume lines to the diaphragm, it's on the right rear on the engine. Push button are all vacume diaphragm operated. You can engage it buy hand (not fun) but down on the passenger side of the mid section of the tranny is the arm, push it forward or back and it should go in 4x. -Prwa
December 2, 201312 yr Happened to me at that plastic thing on the passenger side under the hood... broke a nipple off it slightly.. could barly tell but sure wount engage for anything.
