December 7, 201312 yr Anyone know if msd makes a coil / distributor that would work with a ea71 subaru brat its a 1980
December 7, 201312 yr You could most likely modify an MSD dizzy to work if they make one for another vehicle that has similar shaft length and diameter. The blaster coil will work, just be sure to get the ballast resistor. Truth be told, on a stock application, any gain you might get will be negligeable at best and not really worth the money. Hotter spark only helps with higher compression and more fuel.
December 8, 201312 yr im running a cheap pro comp cdi multi spark box on my ea82 makes a big differance even using the stock coil it wont give you more horse power but it will give you a better torque curve its the differance between pulling hills at 50 or pulling the same hill at 65 or first gear wound out up the driveway or sencond gear comfertably up the driveway i unhooked it because of a no spark condition but was somethin else and havent hooked it up yet wish i could give real #s but thats the best i can do also picked up a mpg or 2 yea
December 8, 201312 yr i could take some when i rehook it up but i routed all my wire through the harness so it looks stock hay it fooled the smog guy should have seen his face when he tryed to get a timing reading priceless i hid the box under the factory spare tire finely found a use for that thing lol
December 8, 201312 yr Author Sweet man pm me if u can i would be intrested in talking to u about it i want to do the same to mine!
December 12, 201312 yr I've got a street fire by msd cdi box and a blaster ss coil in my 85 brat. Runs like a top, easier cold start up, better idle.
December 12, 201312 yr Author Ok i want to upgrade the disty on my ea71 but i cant find any is it hard to make ea82 disty work
December 12, 201312 yr Author Im thinking it is breaking down and or going bad. Car runs great till u shut it down for about 20mins and start back up its like its missing i think either the coil or disty one is getting hot and not working correctly
