codes on my 87
ok I checked the ECU codes on my 87 GL-10 and heres what I got
11-crank angle Sensor or circuit
13-Crank angle sensor or circuit. why is there two diff codes for the same thing?
14-fuel injector-abnormal output
21-coolant temperature sensor or circuit
24-air control valve or circuit
31-Throttle sensor or circuit. Is this the TPS?
34-EGR solenoid or circuit
35-purge control solenoid or circuit
42-idle switch or circuit
so how do I check these out? I'm hoping Skip sees this
does the car run at all? that many codes tells me you have a power/ground problem. start by checking your referance voltage(5v) and ground at an easy location. you can do it as the under dash connector if im not mistaken. or at the tps if you dont want to look it up.
Hey JWX
I checked the codes on my ’87 RX this weekend (found out the “check engine light” was missing and the PO was running with the test mode connectors plugged in :rolleyes: ). I got three, O2 sensor, idle switch and neutral switch (does the 5 speed even have one??) I cleared the codes and have been running for 4 day and still no codes.
I’d say clear them first, if it’s a real problem it will pop back up soon. The FSM has procedures to check all the components.
Gary
P.S. I thought the test mode connection was suppose to lock out the timing advance but with the timing light on it, it would still advance from idle (dose it have mechanical advance?), and the car seems to run the same with them disconnected.
Now the Russ mentioned it, I also cleaned and reconnected my main ground cable and body-to-trans ground wire this weekend too.
Gary
yes the car runs. how do I check the referance voltage? and how do I clear the codes
I also need help with codes on my 1987, but with a carb. I've read the how-to page and I'm still confused.
I can't find the connectors to activate any of the modes. There are no orphan connectors under the hood and around the pedals there are only two lonely connectors, but both are female. One's red, the other yellow. Near the firewall in the engine compartment, on the driver's side, there is a six pin female connector.
There is no oxygen sensor, the cat has a threaded plug in it. Without an oxygen monitoring unit with an LED on it, who will I read the codes? The how-to page lists codes for an 1987 with carb so I'm assuming codes are being generated/stored.
Also, I need to find an antibackfire valve.
Thanks,
XR
bumpy bump bump bumpy bump bump look at me bump my thread
referance voltage check
I assume you have acess to a wire diagram?
if not look for the round conector on the tps. it has three wires. ground, 5v ref, and the tps signal. black, red, and white. black is ground, red is signal, and white is 5v ref.
use a volt meter and have fun. if you get stuck let me know.
XR4- 87 carb with no o2 is eiter modified and codes will do you no good or never had a o2 and therefore no codes.
so how do I clear the codes?
