December 27, 201312 yr I have an '83 GL wagon with a Carter-Weber. It has been sitting for ~20 years, so I pulled the carb and cleaned it out. I did not have a manual, so I certainly could have missed something, but I cleaned as much as I could find. After reinstalling everything, the carb is not flowing fuel. It will fire a few times, then die. If I squirt gas directly into the carb it runs fine. The two options would seem to be that a jet or two is still plugged, or the bowl is not filling with fuel.. Could anyone help me understand what all the solenoids do? I also saw mention of a metering rod, what is this/what does it do? Basically, I'm trying to understand the possible causes of no fuel.
December 27, 201312 yr There are several areas to check: What is the condition of the gas tank? What is the age of the gas in the tank? Did you change the fuel filter(s)? Did you check fuel pump output and if so, what is the color of the gas?
December 27, 201312 yr hi, if it has been sitting that long , you needed to #1 , drain all the fuel from the tank first, put in some new gas. next , replace the filters, front ,, and at the pump,, then are you sure the fuel pump is working, and getting fuel to the carburetor? it will not run the pump by just turning on the ignitionto to on, you need to have the motor cranking over or running as you said by putting gas in the carb directly to check it,, after these things are in order you have a good possibility to get it running, but if you are working with the fuel that was in the tank , no way it's going to run. the carter /weber is the odd carb setup but they will work. i think a kit for them is a no go nowdays, if you got it back together right it should run even if rough. by no fuel do you mean it is not getting to the carb ? or just not getting through the carb? post some additional information as to what all you have done and it helps someone to help you out. Edited December 27, 201312 yr by ruparts
December 27, 201312 yr Author The electric fuel pump is dead; I'm currently fueling it from a motorcycle tank held by an assistant. I have checked, I have fuel all the way to the carb.
December 27, 201312 yr hi, i recently tried to gravity feed fuel to my dodge van to make it run, i found that it was not enough pressure to make gas go through the needle and seat into the bowl. just saying , i could not make the gravity work for my carb so maybe it won't do it on this. if you can get a pump to do it it may make life better, i put on a pump and it did the job.
December 28, 201312 yr Author I pulled the carb again today. I found out that the metering rod is solidly stuck in it's seat, not allowing fuel through the main jet.
December 29, 201312 yr Author After letting the metering rod soak in penetrant for a day, then heating it up with a torch, I was able to coax the rod out of its seat. After assembly it ran fairly well, a little hard to start and the accelerator pump is weak, but otherwise it runs fine!
December 30, 201312 yr baby that accelerator pump -It may be the last one on earth. . Kits listed here. http://www.royze.com/kit%20subaru.htm
December 30, 201312 yr . Kits listed here. http://www.royze.com/kit%20subaru.htm Hmmm, where were you when I needed you?
