December 30, 201312 yr Hi, i have a subaru legacy outback 1997 with a ej25 n/a . I installed a new engine ej25 jdm n/a .. The same specs. But my automatic transmission busted . I want to know witch transmission fit on my subaru .. I want something bolt on.. Thank you for your help
December 30, 201312 yr 4.44 gears 95-99 outbacks and foresters the legacy one is same but is 3.90 or 4.11 ratios But could swap your front diff if needed
December 30, 201312 yr legacy one is same but is 3.90 or 4.11 ratios But could swap your front diff if needed 2.5 liter legacys should also be 4.44 - like GT's and LSi Edited December 30, 201312 yr by grossgary
December 30, 201312 yr you can use any auto trans from 96 - 98 from a 2.5L car, Outback, Forester, GT, LSi, in that order. the GT and Lsi will throw off your speedo a little. check out www.car-par.com , put in your zip and sort by distance. search each year and model separately.
January 2, 201412 yr So... 2.5 auto trans Legacy GT, LSi, and Outback from 95-99 have 4.44 FDR? Any idea what 1-4 ratios are on that trans?
January 2, 201412 yr Any idea what 1-4 ratios are on that trans? i have no idea. but subaru is such a small car company, it is very costly for them to have a ''special'' trans. generally speaking, in the late 90s, from the trans oil pump back, all the trans are the same. only the front difffs are different. i have heard some say this is not 100% correct for all years and all models, but is is close enough so that the trans will move the car.
