February 22, 201412 yr I have a 1996 Outback with 2.5 engine , has P0420 code, any suggestion , there are no any other code for engine misfire
February 24, 201412 yr How may miles on the car? A p0420 can be the result of a o2 sensor getting lazy. If it's running fine you can reset it if the CEL is still on and see if it returns. I had one that would pop the CEL after a highway run at higher speeds every 6 months or so. I'd just reset it since it ran fine and there was no drop in MPG. As long as it was well before the emission check the car still passed without trouble.
March 2, 201412 yr Probably a poop'd out o2 sensor, or you need a cat.. If I remember right, the 420 codes are cat related. And or stoner related.. heyoh! haha Edited March 2, 201412 yr by Sdam87
March 2, 201412 yr there are many things that can cause that code. even exhaust leaks. http://www.subaruoutback.org/forums/66-problems-maintenance/49537-p0420-diagnosis.html
March 2, 201412 yr Catalyst efficient code...Remember catalytic converters just don't go bad...something causes them to go bad, so if you just slap a new set of cats on it chances are you'll have the same problem down the road
March 3, 201412 yr how long have you owned it? when were the headgaskets replaced? annoying code. there's about 1,000 things that can cause it. best off just ignoring it. being a 1996 you can get an exemption from emissions due to a 1996 specific issue. so it shouldn't matter at all if the check engine light is on. fix any exhaust leak seafoam the intake fuel additive new NGK OEM plugs New OEM wires you're not likely to find a mechanic capable of properly diagnosing what is causing it so they'll usually just throw a new catalytic converter and O2 sensor at it even though that's not likely the cause.
