87 gl-10 not charging
So my gl-10 isnt charging. Tried two diff alterternators that i know are good.( both tested out at orielys with 14.7v. All the fuses are good. And aldo no fuses are drawing power when the car is off. Im going to do more testing tomorrow, but im wondering if someone has had the same kinda issue or any advice on it. Its causing the car to run horribly due to the fact its just running off the battery.
Is that balck fusible link in fuse box thats next to battery good? The one closest to strut tower. Or is it making a good connection on bottom of fuse box and off of alternater?
The black fusable link is good. Ill double check all the connections tomorrow. Its just weird it worked fine before the motor was pulled and its back in now and not working! Ill update on what i find tomorrow
my car's had pretty bad wiring luck around there. Mine did it before because the little two prong connector going into that alt. had a bad connection, and its done that because the black fuses base burnt up underneath the box
The twin plug that goes into the back, should there be 12v at both with ignition on? Ive got 12v to the battery wire. If so it was probly just a bad contack. I cleaned and tightened them up in the plug. Cant test it yet cu the alternator is wet... with paint ;)
Got it all figured out. It was just the plug in the back not making connection. So its all fixed now
