elgigante Posted June 3, 2014 Share Posted June 3, 2014 (edited) So I need help on how to dial this two plug tps in. Mine has two wires going to the tps (room for 2) then a plug with three wires. Anyhelp? And is there any way to mod a different tps to this car as I cannot find one anywhere Edited June 3, 2014 by elgigante 1 Quote Link to comment Share on other sites More sharing options...
jono Posted June 3, 2014 Share Posted June 3, 2014 post#12 http://www.ausubaru.com/forum/showthread.php?t=24716&highlight=wire+EA82+mpfi&page=2 has direct copy and paste from a recent post in here, linked from a link in a post from last few days on the spider on an 85 turbo ....problems etc Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 3, 2014 Author Share Posted June 3, 2014 Hey thanks, kinda confusing though, to me it says you can use a spider tps, but then you cant. Am I reading this right? "To make this style work with a Spider TPS you just need to combine the 2 ground wires(or just cut ff one of them, since they are already combined further up the harness) and match the remaining 3 to their respective pins(power, signal, Idle) on the Spider TPS. As far as using a Spider TPS with the older type, I can't see how it would work. The old style is not a potentiometer" Quote Link to comment Share on other sites More sharing options...
ivans imports Posted June 3, 2014 Share Posted June 3, 2014 I might have one Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 3, 2014 Author Share Posted June 3, 2014 I got a rx tps. Its a 3 plug. Could I make this work? Quote Link to comment Share on other sites More sharing options...
wagonist Posted June 4, 2014 Share Posted June 4, 2014 You can use a 4 wire off a Spider manifold engine, as there is a common earth wire that branches to both of the 2 & 3 plugs. But the 3 pin is missing the "potentiometer" part, and only has idle & full throttle switches. Not sure why you can't find one, all of the 88- MPFI cars should have one. Could post you one from here Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 4, 2014 Share Posted June 4, 2014 spider rotate backwards. you need correct TPS. 1 connector is just for Idle switch....this is the one with 2 wires in it.....just make it so there is continuity to ground when idle throttle closed, but open when throttle is opend just a hair...... the other connector is the actual potentiometer that measures throttle angle....if you set the switch correct...then the potentiometer part will just do it's thing. Quote Link to comment Share on other sites More sharing options...
wagonist Posted June 5, 2014 Share Posted June 5, 2014 spider rotate backwards. you need correct TPS. 1 connector is just for Idle switch....this is the one with 2 wires in it.....just make it so there is continuity to ground when idle throttle closed, but open when throttle is opend just a hair...... the other connector is the actual potentiometer that measures throttle angle....if you set the switch correct...then the potentiometer part will just do it's thing. You sure? The normal MPFI TPS is on the right side of the engine with the cable on the left pulling from the rear & down. The spider manifold TPS is on the left with the cable pulling from the front and up. So in my mind they're both turning the same way, just confusing with the different orientation of the throttle body. My spider manifold engine was previously running a 3 pin TPS (cos a "black" ECU was being used), so it doesn't have the 4 pin version. I'm planning on using one of these 5 pins on it instead. Quote Link to comment Share on other sites More sharing options...
ivans imports Posted June 10, 2014 Share Posted June 10, 2014 I have two one has a round con on pigtail one has a rectangle con on pigtail both 3 wires both same wires. Looks ok came off a ea82 T 1989 round plug one is off 1988 model Quote Link to comment Share on other sites More sharing options...
elgigante Posted June 22, 2014 Author Share Posted June 22, 2014 so how do I go about multimetering this thing out? Quote Link to comment Share on other sites More sharing options...
