SVX power steering lines
Hello everyone!
Recently, got SVX to drive around for fun. So far so good, but would like to fix the power steering lines. Getting too muscular from just driving around :)
Looked underneath and looks like one of the power steering lines is rusted and needs to be replaced, don't know which one tho, and if I will replace this one, wouldn't the other ones break also?
My question is if anyone knows where to get this power steering lines?
Thank you!
Dealer may still have one. Also any local business that repairs farm tractors or sells new ones can just make a new line for you.
you dont mention what year yours is, but SubaruGenuineParts.com lists a hose for the SVX as being "from 6/92" - I selected 94 in the search...
You may want to call and verify before ordering first...
https://www.subarugenuineparts.com/oe_parts_cat.html
edit: ok - so that just takes you to the main catalog page, click on "more" just under Impreza, then select SVX, and go from there...
Edited by heartless
they DIY would be for the return line only - low pressure...
high pressure side should be the right type of hose with proper high pressure connections
