June 21, 201411 yr has anyone ever tried a chain drive system with the mt-5 trans i am doing this for a number of reasons primarily due to the placement of the engine/trans in relation to the location of the rear wheels secondly is ground clearance thirdly is the reason for a 4 wd trans so i could tub out the buggy and hit some deep water with a prop out the back the finished product is gonna be interesting to say the least an thoughts about the system has anyone tried it yet thanks for the thought yall tampaboater pictures to come build it... beat on it... break it... rebuild it better
June 21, 201411 yr sounds cool, with proper engineering it should work fine, keep the outer bearings close to the sprockets and have good suport between bearing, dont want any flex or chains will pop off, I know from my own experience
June 21, 201411 yr Here's my attempt at something similar it may float depending on the tires. I keep meaning to look into rating tires for floatation I've seen big quads float with the tires in running http://www.ultimatesubaru.org/forum/topic/140418-distractions/
June 22, 201411 yr Author well guys update found a carb good for rebuild sittin around today need to get an adapter plate for it was told some one on here makes em but not sure who any leads thanks
June 29, 201411 yr build link? wish i had one... sorry :/ cant find any build info for it naw I turned off my net and all I have is a phone but I seen it and I've seen it before doesn't seem that fun to drive
July 6, 201411 yr Author got the carb kit in the other day waitin on the fly wheel to come back... looking at a few different options there i will let yall know how it works getting the c/v shafts back next week just need to find the right sprocket chain combo for what i want i will keep yall posted
