1998 Outback Seat Cushion Discontinued
HI, I have a 1998 Outback that I'd like to replace the drivers seat cushion. The fabric is still in good condition but the pad is worn/broken down. I called the dealer and was give part number 64220AC500 and told it was discontinued. by the way the cost of the discontinued cushion was over $300. There is another part number of 64220AC520 for $96 that they told me would not fit my VIN. Does anyone know the difference between the 2 part numbers and has anyone tried it?  I saw other posts of people buying the pad from the junk yard or swapping the passenger seat pad but all the ones I can find are in just as bad of shape. Any insight is appreciated. Thanks!
I'd just take it to a reputable upholstery shop. I'm sure they can rebuild the seat cushion or whatever they do.
I haven't taken these seats apart, but there's a chance the passenger side seat bottom would work on a driver side seat. I've done that on other cars before. Passenger seats are usually in better shape at the junkyard.
Edited by 987687
Yep, just grab a good passenger side.
Easy to get out at the yard, just cut the material and remove the complete pad.
i can get complete seats for $40 at the local UPAP self serve yard.
$60 shipped, I'll grab you a good foam pad and ship it.
Get some stiff foam pad from a fabric store. Cut sections to match the shape of the ones in the seat. Not too bad to do if you have a good sharp knife. Razor blades work as well just takes a few extra swipes.
For cutting foam to shape nothing beats a good electric knife.
3M spray adhesive works well on foam.
I repaired my driver seat foam in my 99 OBW last year. I went to a wrecking yard, and bought a Subaru passenger seat that had good foam. I disassembled the seat to harvest the foam. I then swapped in the foam into my driver's seat. I used cable ties to replace the hog clips securing the fabric, that I had cut off earlier  It didn't take much time to do the swap out. Repaired seat looks and feels like new. Rides lots easier on my butt too.
