July 22, 201411 yr Let me start by saying that I used the search function and found a few older threads with not much information about them; and instead of resurrecting I have decided to make a new thread to approach this subject. To the subject... Has anyone found an alternative to the chrome bed trim that our Brats use? I have been looking at weather stripping and all sorts of things trying to come up with something wide enough and tall enough; but have yet to find a suitable match. My other option would be to pull the chrome off, sand it all down, and run bed liner over it too. But I was looking for something aftermarket, that was a bolt on replacement in non-chrome. Any ideas? They would be appreciated. Thanks!
July 22, 201411 yr As far as your 1st. option, haven't heard of anyone having any luck with that. It would be a real shame to liner your trim if it is in nice shape. If it's beat to spoob, go for it. knock out as many dents/dings as you can. Maybe use some body filler to smooth it out and line away!
July 22, 201411 yr Author I have looked at tons of pictures of Brats and have yet to find one without the chrome... The trim I have is somewhat beat-up and running bed liner over it wouldn't be a shame. Was just trying to find something that would be a but more solid and a cover the screw holes and pinch weld... I may try to form a piece of aluminum over the weld and screw it down after covering it with bed liner.
July 23, 201411 yr I had great success on the wheel trim on my '81 by pulling it off and then doing some good old fashioned sheet metal work to tap out the bumps. I then wet-sanded the imperfections with progressively finer grits and finally polished it. By itself, that probably wouldn't work for the chrome trim, but it might help. Of course, if you don't mind spending the money, you could then get it re-plated. Edited July 23, 201411 yr by bendecker
July 23, 201411 yr Some country's got hook bed brats where instead of the chrome trim they got really useful tie down hooks in place of the chrome. Couldn't find a pic since they're rare but did find some pics of the long bed brats. Edited July 23, 201411 yr by turbosubarubrat
July 23, 201411 yr Author Knowledge of something is search engine power. https://c1.staticflickr.com/9/8180/8038095172_6d102b9e40_z.jpg Appears to be part of the bed though, not something that bolts down.
July 23, 201411 yr Thats a killer idea! Looking at that you could weld on a piece of 3/4" "L" and make your own. You can bend that stuff fairly easily at a shop too, for the odd corners, or snip and weld it to shape. For that matter any machine shop could brake you a piece to fit just the tailgate. I figure I'm going to have to go this route because thats the only piece I'm missing. (but now I'm not so sure....)
July 23, 201411 yr Author I am still trying to locate some rubber pinch-weld molding that sticks out an extra 2" on one side in order to cover up the screw holes. Nothing yet; really looks like I will probably take mine off, sand them down, and cover with something. this guys end result looks decent enough:
July 23, 201411 yr What we REALLY need is the plastic "nuts" that fit into the square holes and then accept the screws. Anybody got a 3d printer?
July 23, 201411 yr Maybe stick it down with some Liquid nails (that sploob is tough) then fill in the holes? I'm guessing you want a smooth one piece look?
July 23, 201411 yr I replaced several of the broken plastic pieces on mine with a small wedge shaped block of wood. Marine caulked it in place and they are still there after many years. I sanded mine down and had them shot black with the last paint job. Probably 5 years ago.
July 23, 201411 yr Author Plastic Grommet (Square) - Subaru OEM Part Number = 791017130 Then there is a round grommet for the corner bits... no idea what that part number is.
July 23, 201411 yr as long as you have enough of the clip to be a "spacer" i have just drilled right through and used a machine bolt and nut with a big washer on the bottom - only works for the ones you can get to the underside of.
July 23, 201411 yr will get a pic of the barwork i built for my "farm" brat too kind of protects the trim
July 24, 201411 yr I had the same problem. The bed trim was beat all to heck. Spent many hours knocking out the dents and sprayed it with Raptor Liner. I think it looks better than the chrome look.
July 27, 201411 yr Author I think I have decided on getting the chrome sand blasted and powder coated. I wish I had a machine that could lathe out rubber molding.
July 27, 201411 yr Beautiful! Was that roll bar stock? Thanks. No, not stock. I bought a 1981 Brat just for the roll bar and seats but the bar did not fit correctly, so I found some tubing that came from an old swimming pool ladder and diving board and adjusted the bends and welded it to fit the way I wanted. The truck does have the jump seats in the back now.
August 4, 201411 yr I wish I could find the stainless trim for my tailgates...dang things are always missing on these trucks.
August 11, 201411 yr I wish I could find the stainless trim for my tailgates...dang things are always missing on these trucks. I've got one in the for sale forum...
