July 23, 201411 yr Howdy. I have a 96 legacy outback with 5 speed and ej22. I keep hearing a thudding type noise near the rear passenger wheel when i let the clutch out. it also makes a humming noise when I'm in 5th gear cruising along and take my foot off the accelerator. I'm thinking it might need a new wheel bearing or axle? Any ideas or help would be sweet. I have changed the tranny and rear differential fluid, but it didn't help the matter. cheers- will
July 23, 201411 yr Check for loose or failing driveshaft u-joint. Check the hanger bushing on the riear diff. In this order.Check the rear diff fluid.Go under the car and try to turn the driveshaft by hand feeling for play.
July 24, 201411 yr My vote is for the hanger bushings. They wear out with age and will cause this type of noise and the gearbox engages or as the car changes speed speed rapidly. O.
July 24, 201411 yr Author Well played there kind folks. it was definitely the hanger bushings. can't believe i couldnt figure that out on my own. thanks for the help. All better now. cheers-will
